SJeon37
5 years agoMAX 10 ADC Sequencer Core Command Register Setting
I am testing the ADC in FPGA MAX 10 (10M50DAF484C6GES).
With reference to the example code below, it seems that the adc operation does not stop even if the RUN bit is set to 0.
I would like to know how to set the stop bit and how to set it in one cycle ADC mode.
Thank you for your help.
https://www.youtube.com/watch?v=u7y5ZR1E8SU
module sequencer (
Clock_qsys,
Reset,
AdcCsrAddress, //Address to CSR for ADC for setup
AdcCsrReadEn, //Read enable for CSR for ADC for setup
AdcCsrReadData, //Read data for CSR for ADC for setup
AdcCsrWriteEn, //Write enable for CSR for ADC for setup
AdcCsrWriteData, //Write data for CSR for ADC for setup
reset_btn
input Clock_qsys;
input Reset; //Synchronous Reset
output reg AdcCsrAddress; //Address to CSR for ADC for setup
output reg AdcCsrReadEn; //Read enable for CSR for ADC for setup
output reg [31: 0] AdcCsrReadData; //Read data for CSR for ADC for setup
output reg AdcCsrWriteEn; //Write enable for CSR for ADC for setup
output reg [31: 0] AdcCsrWriteData; //Write data for CSR for ADC for setup
input reset_btn;
reg [2:0] CurrentState;
reg [2:0] NextState;
initial
begin
CurrentState = 0;
NextState = 0;
end
always @(posedge Clock_qsys)
begin
// if(Reset) begin
// CurrentState <= 0;
// end else begin
CurrentState <= NextState;
// end
end
//Next state logic
always @(CurrentState)
begin
//Default to not asserted
AdcCsrAddress = 1'b0;
AdcCsrReadEn = 1'b0;
AdcCsrReadData = 32'b0;
AdcCsrWriteEn = 1'b0;
AdcCsrWriteData = 32'b0;
case(CurrentState)
0, 1, 2, 3, 4, 5:
//Go through delay chain to let ADC module finish reset
NextState <= CurrentState + 1;
6 :
//Write enable bit and finish
begin
AdcCsrWriteEn <= 1'b1; //Write data to CSR
AdcCsrWriteData <= 32'h0000001; //Enable continuous run mode
end
7 :
begin
AdcCsrAddress <= 1'b0;
AdcCsrReadEn <= 1'b0;
AdcCsrReadData <= 32'b0;
AdcCsrWriteEn <= 1'b0;
AdcCsrWriteData <= 32'b0;
NextState <= 7;
end
endcase
end
endmodule
