Linux not booting - can't get kernel image
- 8 months ago
Hi pmarques
From this thread, I see the the JTAG_USER_CODE is being set a 4 as it was set with that value in the example design used for the SD_CARD daughter card. I think that in the new design, this should be either 0 or undefined:
You can find this value from Quartus in the Assignments >> Device >> Device and Pin Options >> General.
Also you may find this in your .qsf:
set_global_assignment -name STRATIX_JTAG_USER_CODE 4
So, you can either change this value to 0 or remove it.
There is some documentation about how this JTAG_USER_CODE was used in GSRD 1.0
https://www.rocketboards.org/foswiki/Documentation/SingleImageBoot , Seems that something about this is still used in GSDR 2.0, but the board IDs changed in GSRD 2.0.
In this file you will see how the kernel.itb is created. This includes 2 sets of images: board-0 and board-1. The USER_CODE=0 will use the board-0 configuration and USER_CODE=1 will use the board-1 configuration (it's the same but doesn't include the core.rbf in the kernel.itb. I am guessing that when this is not defined it will use also the board-0 configuration.
Hi Tehjingy,
Apologies for the delay, please see the requested files in attachment.
PM.
Hi pmarques
It seems like the kernel.itb that you generated is incorrect.
As you see the kernel.itb do not consist a configuration3 ( board 4)
e.g Pre-built Kernel.itb
That is the configuration for the uboot environment.
Could you try booting the board with the pre-built sdcard image?
tehjingy
