is there a bug in the Ethernet MAC of Arria10 SoC devices?
I have not seen such issues occurs before. Did you change or modify any Uboot or devce tree configs?
Also, you mentioned you are using EMAC1, but ifconfig eth0 down and ifconfig eth0 up to exit the high latency issue. Why are you doing it on the eth0 instead of eth1?
Can you check if you have set the correct EMAC* in the device tree:
"Ubootdirectory\arch\arm\dts"
- Silvan5 years ago
Hi Eberlazare,
Thanks for your feedback.
This issue is not observed in u-boot but on a running Linux. Our hardware has only one Ethernet connection which use EMAC1 (EMAC0 is disabled). In the Linux device tree the EMAC1 configuration is connected to ethernet0 (aliases section) which result in the naming eth0 on Linux.
Bellow you find the Linux device tree entry for the ethernet configuration.
Do you think there is something wrong? Or what could be the reason for this high Ethernet latency?
hps_gmac: ethernet@ff802000 { compatible = "altr,socfpga-stmmac", "snps,dwmac-3.72a", "snps,dwmac"; altr,sysmgr-syscon = <&sysmgr 0x48 8>; reg = <0xff802000 0x2000>; interrupts = <0 93 4>; interrupt-names = "macirq"; /* Filled in by bootloader */ mac-address = [00 00 00 00 00 00]; snps,multicast-filter-bins = <256>; snps,perfect-filter-entries = <128>; snps,axi-config = <&socfpga_axi_setup>; tx-fifo-depth = <4096>; rx-fifo-depth = <16384>; clocks = <&l4_mp_clk>, <&peri_emac_ptp_clk>; clock-names = "stmmaceth", "ptp_ref"; resets = <&rst 33>, <&rst 41>; reset-names = "stmmaceth", "stmmaceth-ocp"; phy-mode = "rgmii-id"; max-frame-size = <3800>; /* probe for phy addr */ phy-addr = <0xffffffff>; txd0-skew-ps = <420>; /* 0ps */ txd1-skew-ps = <420>; /* 0ps */ txd2-skew-ps = <420>; /* 0ps */ txd3-skew-ps = <420>; /* 0ps */ rxd0-skew-ps = <420>; /* 0ps */ rxd1-skew-ps = <420>; /* 0ps */ rxd2-skew-ps = <420>; /* 0ps */ rxd3-skew-ps = <420>; /* 0ps */ txen-skew-ps = <420>; /* 0ps */ rxdv-skew-ps = <420>; /* 0ps */ txc-skew-ps = <1440>; /* 540ps */ rxc-skew-ps = <1680>; /* 780ps */ status = "okay"; };- EBERLAZARE_I_Intel5 years ago
How did you define the clock skews? Is it default? Where did you get them?
Have you run on different versions of Linux? Preferably 5.4
- Silvan5 years ago
Hi Eberlazare,
The skews are calculated based on the trace length and FPGA Pin delays on our custom board and firmware.
I tried it also once with a really early version of kernel 5.4. And at least in the MAC driver I didn't saw any changes since then.
May it is possible to reproduce the issue with an Arria10 development board? Unfortunately, our development board still has an ES2 device which isn't available in Quartus to build the GHRD. When you have an image for this development board I could also try to reproduce the issue on this hardware...?
