IPv6 Ethernet Connection Not Found using udhcpc command
Please send the screenshot of "ifconfig" command.
Did you set the IP address or is it connected in DHCP mode?
Tiwari
- road_runner2 years ago
Hi Jeet14,
Attached is the ifconfig for the board I am using. I do have another problem that I didn't realize. When I switch it back into normal operating mode for the MSEL, despite no issues showing in Eclipse, I receive an error stating that it cannot launch the ELF file. Everything looks fine with the target connection, no errors will show under Run Configurations, and then I get that message. Not sure if they are connected, but as they're both (if I understand correctly) intended to be used with the wired serial connection (even though the udhcpc is also used for wireless connectivity) I thought it was worth bringing up. If not, it is a separate issue that I need to start a new post over as I do need to be able to use the udhcpc command to find the IPv6 address. Many thanks in advance!
