Prasannaijayakumar
1 year agoIntel Agilex 5 HPS -> SDM mailbox
I want to implement the HPS -> SDM mailbox communication in linux for INTEL Agilex 5 chipset. I find there are two ways to do it. One is through the direct mailbox configuration through the memory ...
Jeet14
1 year agoHi,
Are you looking for reading the different temperature values from the device using the linux? If yes, then you need to use the mailbox client IP.
Tiwari
- Prasannaijayakumar1 year ago
Hi Tiwari,
Sorry for the late response. I did not get the email notification hence i missed your reply.
My assumption is that we have to send a HWMON READ TEMP SMC command to the ATF and ATF will handle the mailbox part and provide the response through the SMC call. Please correct me if i am wrong.
