jlats2's avatar
jlats2
6 years ago
hps-fpga problems with makefile error: #error You must define soc_cv_av or soc_a10 before compiling with HwLibs
I am having issues making my C file with the EDS editor. I am using 18.1 . My goal is to compile my C code with the below make file. However, whenever I attempt to run the make file, I get the following error:
$ make
C:/intelFPGA/18.1/embedded/ip/altera/hps/altera_hps/hwlib/include/hwlib.h:56:2: error: #error You must define soc_cv_av or soc_a10 before compiling with HwLibs
I have read some forum posts which suggest to include this in the make file:
ALT_DEVICE_FAMILY = soc_cv_av
however, this has not helped me.
Any suggestions?
Here is my make file:
TARGET = my_first_hps-fpga
CROSS_COMPILE = arm-linux-gnueabihf-
CFLAGS = -static -g -Wall  -I${SOCEDS_DEST_ROOT}/ip/altera/hps/altera_hps/hwlib/include
LDFLAGS =  -g -Wall
CC = $(CROSS_COMPILE)gcc
ARCH= arm
build: $(TARGET)
$(TARGET): main.o
	$(CC) $(LDFLAGS)   $^ -o $@
%.o : %.c
	$(CC) $(CFLAGS) -c $< -o $@
.PHONY: clean
clean:
	rm -f $(TARGET) *.a *.o *~
and here is the top portion of my c file:
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/mman.h>
#include "hwlib.h"
#include "socal/socal.h"
#include "socal/hps.h"
#include "socal/alt_gpio.h"
#include "hps_0.h"
Thank you,
James
  • MHawk6's avatar
    MHawk6
    Have you checked out the example projects included with your Demo Board? It may be a simple syntax error.
    According to the documentation, the makefile should contain:
    ALT_DEVICE_FAMILY ?= soc_cv_av
  • jlats2's avatar
    jlats2
    Thank you for your reply.
    ​I was suspicious of a typo myself at first. Fortunately my demo board (de0 nano SOC) provides a make file and main.c file which I have been using so I don't think that I have any typos.
    I'm wondering if it has something to do with the version of EDS that I am using. I think the de0 nano board came out on version 13.1 so I might try downloading that to see if it helps any. But I feel like there must be a way to make it work for EDS version 18.1 (and later). Do you have any other suggestions?
    Thank you,
    James
  • jlats2's avatar
    jlats2
    Thank you for your reply AnilA.
    So I did see that forum post in the past and when I tried it, it did not work for me. However, this time whenever I tried it, I moved my make file and main.c file into the directory structure of my 18.1 EDS and now it seems to work. I still need to load the executable into the fpga to verify results. Does this seem reasonable to you? I would think that I should be able to run makefiles in any folder that I can navigate EDS into. What are your thoughts?
    C:\intelFPGA\18.1\embedded\ is where the Embedded_Command_Shell.bat
    C:\intelFPGA\18.1\embedded\hps-c is where my make file and main.c fileare
    see the below screen shot:
    copy of my make file (for whoever it may help):
    James
    # This is the name of the binaries that will be generated
    TARGET                  = de1_soc_hps_binary
    # The device family (soc_cv_av = Cyclone V   ;   soc_a10 = Aria 10)
    # Some paths (Default should work)
    HWLIBS_ROOT             = ${SOCEDS_DEST_ROOT}/ip/altera/hps/altera_hps/hwlib
    # Here we add all *.c files that we want to compile
    CSRCS                   = main.c
    # Here we add all *.cpp files that we want to compile
    CPPSRCS                 =
    # Here we add the paths to all include directories
    INCS                    =
    # Parameters for SCP upload. Set up SSH keys to bypass password prompt
    SCP_TARGET_IP           = 192.168.1.100
    SCP_USER                = root
    SCP_TARGET_PATH         = /home/root
    SCP                     = SCP
    SCP_FLAGS               =
    # Compiler settings
    ARCH                    = arm-linux-gnueabihf
    LD                      = $(ARCH)-g++
    CC                      = $(ARCH)-gcc
    CPPC                    = $(ARCH)-g++
    SIZE                    = $(ARCH)-size
    CFLAGS                  = -g -std=gnu99 -Wall
    CPPFLAGS                = -g -std=c++11 -Wall
    LDFLAGS                 = -g -Wall
    # Don't change anything below this line                                        #
    # Some directory and file magic
    BUILDDIR                = build
    OBJDIR                  = $(BUILDDIR)/obj
    # Generate the object names
    OBJS                    = $(addprefix $(OBJDIR)/,$(addsuffix .o,$(basename $(CSRCS:%.c=%.o))))
    OBJS                    += $(addprefix $(OBJDIR)/,$(addsuffix .o,$(basename $(CPPSRCS:%.cpp=%.o))))
    # Add some paths
    CFLAGS                  += $(INCS:%=-I%) -I$(HWLIBS_ROOT)/include -I$(HWLIBS_ROOT)/include/$(ALT_DEVICE_FAMILY) -D$(ALT_DEVICE_FAMILY)
    CPPFLAGS                += $(INCS:%=-I%) -I$(HWLIBS_ROOT)/include -I$(HWLIBS_ROOT)/include/$(ALT_DEVICE_FAMILY) -D$(ALT_DEVICE_FAMILY)
    LDFLAGS                 += $(INCS:%=-I%)
    # This is the default target if the user does just calls 'make'
    all: build size
    # Build all the files
    build: builddirs $(BUILDDIR)/$(TARGET)
    # Create the required directories (if not already existing)
    builddirs:
    	@mkdir -p $(BUILDDIR)
    	@mkdir -p $(OBJDIR)
    # Link everything together
    $(BUILDDIR)/$(TARGET): $(OBJS)
    	@echo Linking $@
    	@$(LD) $(LDFLAGS) -o $(BUILDDIR)/$(TARGET) $(OBJS)
    # Compile c files
    $(OBJDIR)/%.o: %.c
    	@mkdir -p $(dir $@)
    	@echo Compiling $^
    	@$(CC) $(CFLAGS) -c -o $@ $^
    # Compile cpp files
    $(OBJDIR)/%.o: %.cpp
    	@mkdir -p $(dir $@)
    	@echo Compiling $^
    	@$(CPPC) $(CPPFLAGS) -c -o $@ $^
    # Print size information
    	@echo
    	@echo
    	$(SIZE) $^
    # Clean up
    clean:
    	@rm -rf $(BUILDDIR) $(OBJS) $(TARGET) $(TARGET).* *.a *.o *~
    	@echo Done
    # Clean must be a phony target so make knows this never exists as a file
    .PHONY: clean
    # Upload to target
    upload:
    	$(SCP) $(SCP_FLAGS) $(BUILDDIR)/$(TARGET) $(SCP_USER)@$(SCP_TARGET_IP):$(SCP_TARGET_PATH)
    • JoshF's avatar
      JoshF
      Thank you so much James, this worked for me. I was close to failing this project in school. You are a gem!
  • jlats2's avatar
    jlats2
    Just a follow up, I was able to load the binary onto the de0 soc board and control the FPGA LEDS from the HPS (so cool!).
    I have no idea whey the EDS is so picky, but maybe this is just one of those 'tips and tircks' to keep in mind.
    James
