hps-fpga problems with makefile error: #error You must define soc_cv_av or soc_a10 before compiling with HwLibs
Thank you for your reply AnilA.
So I did see that forum post in the past and when I tried it, it did not work for me. However, this time whenever I tried it, I moved my make file and main.c file into the directory structure of my 18.1 EDS and now it seems to work. I still need to load the executable into the fpga to verify results. Does this seem reasonable to you? I would think that I should be able to run makefiles in any folder that I can navigate EDS into. What are your thoughts?
C:\intelFPGA\18.1\embedded\ is where the Embedded_Command_Shell.bat
C:\intelFPGA\18.1\embedded\hps-c is where my make file and main.c fileare
see the below screen shot:
copy of my make file (for whoever it may help):
James
# This is the name of the binaries that will be generated
TARGET = de1_soc_hps_binary
# The device family (soc_cv_av = Cyclone V ; soc_a10 = Aria 10)
ALT_DEVICE_FAMILY = soc_cv_av
# Some paths (Default should work)
HWLIBS_ROOT = ${SOCEDS_DEST_ROOT}/ip/altera/hps/altera_hps/hwlib
# Here we add all *.c files that we want to compile
CSRCS = main.c
# Here we add all *.cpp files that we want to compile
CPPSRCS =
# Here we add the paths to all include directories
INCS =
# Parameters for SCP upload. Set up SSH keys to bypass password prompt
SCP_TARGET_IP = 192.168.1.100
SCP_USER = root
SCP_TARGET_PATH = /home/root
SCP = SCP
SCP_FLAGS =
# Compiler settings
ARCH = arm-linux-gnueabihf
LD = $(ARCH)-g++
CC = $(ARCH)-gcc
CPPC = $(ARCH)-g++
SIZE = $(ARCH)-size
CFLAGS = -g -std=gnu99 -Wall
CPPFLAGS = -g -std=c++11 -Wall
LDFLAGS = -g -Wall
# Don't change anything below this line #
# Some directory and file magic
BUILDDIR = build
OBJDIR = $(BUILDDIR)/obj
# Generate the object names
OBJS = $(addprefix $(OBJDIR)/,$(addsuffix .o,$(basename $(CSRCS:%.c=%.o))))
OBJS += $(addprefix $(OBJDIR)/,$(addsuffix .o,$(basename $(CPPSRCS:%.cpp=%.o))))
# Add some paths
CFLAGS += $(INCS:%=-I%) -I$(HWLIBS_ROOT)/include -I$(HWLIBS_ROOT)/include/$(ALT_DEVICE_FAMILY) -D$(ALT_DEVICE_FAMILY)
CPPFLAGS += $(INCS:%=-I%) -I$(HWLIBS_ROOT)/include -I$(HWLIBS_ROOT)/include/$(ALT_DEVICE_FAMILY) -D$(ALT_DEVICE_FAMILY)
LDFLAGS += $(INCS:%=-I%)
# This is the default target if the user does just calls 'make'
all: build size
# Build all the files
build: builddirs $(BUILDDIR)/$(TARGET)
# Create the required directories (if not already existing)
builddirs:
@mkdir -p $(BUILDDIR)
@mkdir -p $(OBJDIR)
# Link everything together
$(BUILDDIR)/$(TARGET): $(OBJS)
@echo Linking $@
@$(LD) $(LDFLAGS) -o $(BUILDDIR)/$(TARGET) $(OBJS)
# Compile c files
$(OBJDIR)/%.o: %.c
@mkdir -p $(dir $@)
@echo Compiling $^
@$(CC) $(CFLAGS) -c -o $@ $^
# Compile cpp files
$(OBJDIR)/%.o: %.cpp
@mkdir -p $(dir $@)
@echo Compiling $^
@$(CPPC) $(CPPFLAGS) -c -o $@ $^
# Print size information
@echo
@echo
$(SIZE) $^
# Clean up
clean:
@rm -rf $(BUILDDIR) $(OBJS) $(TARGET) $(TARGET).* *.a *.o *~
@echo Done
# Clean must be a phony target so make knows this never exists as a file
.PHONY: clean
# Upload to target
upload:
$(SCP) $(SCP_FLAGS) $(BUILDDIR)/$(TARGET) $(SCP_USER)@$(SCP_TARGET_IP):$(SCP_TARGET_PATH)- JoshF1 year ago
Thank you so much James, this worked for me. I was close to failing this project in school. You are a gem!
