HPS f2sdram read/write errors
- We started with the GSRD, but we've made changes since then.
- We're booting all the way into Linux.
- The bridge enable command is present in the U-BOOT boot arg configuration.
We are using HPS-first boot configuration. Is it possible our custom logic is trying to send transactions before the bridge enable has completed its work?
Ok. Great. So, I assume you program the fabric from Linux, right? If so, then bridge enable will be completed well before the Fabric is programmed (of course).
Now, you have probably already done this, but just to make sure I am clear, please read/write from your custom logic to address:
0x00_8000_0000 (0GB physical DDR)
0x08_8000_0000 (2GB physical DDR)
0x09_0000_0000 (4GB physical DDR)
0x09_8000_0000 (6GB physical DDR)
- aucamera16 months ago
Hi Yoda_Altera
Hi Yoda,
Attached are the Read signals from a read cycle to the SDAM. Here I’m showing 00_8000_0000 and 08_8000_0000 address, but the “9” addresses behave the same
thanks
- Yoda_Altera6 months ago
Hi aucamera1,
Thanks for those snapshots. Let me do some investigation here and I will get back to you soon.
Hi Aucamera1,
Please try setting the AxUSER to 0xE0 for F2SDRAM transactions:
0xE0 = SDRAM direct
0x04 = CCU
