sujan19
1 year agoHow to customize the Agilex 7 I-series OS build with SOF and HPS changes ?
Hi Team, So we are working with Agilex 7 I-series Evaluation kit, We have successfully built yocto image for the GSRD as explained in this guide : https://altera-fpga.github.io/rel-24.3.1/embedded...
tehjingy_Altera
1 year agoHi
Yes. The steps for building are the same for the I Series and F series.
If you have created your own custom design you can use your own custom sof instead of the GSRD.
It is recommended to try out the GSRD to understand the over all flow before running your own design.
Besides the Hardware Design, you would also need the SPL, Bootloader, rootfs, Device Tree and Linux Image.
u-boot.itb
socfpga_agilex_socdk.dtb
core-image-minimal-agilex7_dk_si_agf014eb.rootfs.tar.gz
In general these are the required file to boot into the linux environment.
Jingyang, Teh
