awaissman
2 years agoFatal error in Module tennm_noc_fabric_adaptor in file .../sim_lib/tennm_agilex7_io96_ncrypt.sv
Hello, I am trying run simulation for our design after instantiated hps subsystem. Code elaborates but i am getting this error, and it comes from encrypted code: # ** Fatal: (vsim-160) /proj/vendo...
RichardT_altera
5 months agoCould you please try regenerating the msim_setup.tcl file and setting up the simulation script again?
Also, please share the design QAR file (Project > Archive Project) along with the steps used to run the simulation and reproduce the issue.
Richard Tan
zener
5 months agoThe result is the same if I re-build the setup file and all other files from the *.ip files. Unfortunately I can't upload all build software for reproducing the issue.
