Fatal error in Module tennm_noc_fabric_adaptor in file .../sim_lib/tennm_agilex7_io96_ncrypt.sv
I'm using the generated msim_setup.tcl so I don't set up any libraries myself. I simply set variables like TOP_LEVEL_NAME, USER_DEFINED_COMPILE_OPTIONS and USER_DEFINED_ELAB_OPTIONS, but still I get errors like I mentioned earlier in this thread.
Further the directory in the error message /tmp/psgswbuild/nightly/ does not appear on my system and looks more like a directory used by Altera CI (or old Intel PSG).
Could you please try regenerating the msim_setup.tcl file and setting up the simulation script again?
Also, please share the design QAR file (Project > Archive Project) along with the steps used to run the simulation and reproduce the issue.
Richard Tan
- zener5 months ago
The result is the same if I re-build the setup file and all other files from the *.ip files. Unfortunately I can't upload all build software for reproducing the issue.
