Fatal error in Module tennm_noc_fabric_adaptor in file .../sim_lib/tennm_agilex7_io96_ncrypt.sv
Was there ever a solution to this? I just got a similar error during an Agilex5 simulation:
# ** Fatal: (vsim-160) /tmp/psgswbuild/nightly/26.1/110/l64/work/questa_fe/eda/sim_lib/tennm_revb_hvio_ncrypt.sv(145): Null foreign function pointer encountered when calling 'simsf_constra3#_mti_copy_opt_#'
# Time: 0 fs Iteration: 0 Process: /system/top/u_cpu/u_qsys_top/iopll_0/iopll_0/tennm_ph2_iopll/tennm_ph2_iopll_encrypted_inst/#INITIAL#145 File: /net/server/tools/altera/quartus/v26.1.0.110_pro/questa_fse/linux_x86_64/../intel/verilog/src/tennm_revb_hvio.sv
# Fatal error in Module tennm_ph2_iopll in file /net/server/tools/altera/quartus/v26.1.0.110_pro/questa_fse/linux_x86_64/../intel/verilog/src/tennm_revb_hvio.sv
- mguran5 months ago
I'm also getting this error. Based on earlier warnings in the compile process, it looks like it's related to DPI library dependencies in the PLL. I've tried placing -dpiheader arguments in the vsim command, but no luck.
Anyone know how to properly include precompiled DPI libraries in questa sim?
# ** Warning: (vsim-3770) Failed to find user specified function 'simsf_constra3' in DPI C/C++ source files.
# ** Fatal: (vsim-160) /tmp/psgswbuild/nightly/24.3/212/l64/work/questa_fe/eda/sim_lib/tennm_revb_hvio_ncrypt.sv(132): Null foreign function pointer encountered when calling 'simsf_constra3#_mti_copy_opt_#'
# Time: 0 ps Iteration: 0 Process: /adc_interface_tb/adc_interface/gen_adc_receive(0)/n_adc_rec/intel_lvds_0/core/arch_inst/pll_inst/internal_pll/tennm_ph2_iopll/tennm_ph2_iopll_encrypted_inst/#INITIAL#132 File: /home/mguran/intelFPGA_pro/24.3/questa_fse/linux_x86_64/../intel/verilog/src/tennm_revb_hvio.sv
# Fatal error in Module tennm_ph2_iopll in file /home/mguran/intelFPGA_pro/24.3/questa_fse/linux_x86_64/../intel/verilog/src/tennm_revb_hvio.sv
- RichardT_altera5 months ago
Thank you, kbrunham_altera for the suggestion.
mguran please try the suggestion provided by kbrunham_altera and let us know if it works.
If the issue persists, please provide the design QAR file (Project > Archive Project) and the testbench so we can reproduce the issue and investigate further.
Hi mguran
Do you have any update on this?
Richard Tan
