Failed to debug the SMP cycloneVsoc boards
Hello, here are my project settings:
It will initiate an RTOS.
After the RTOS setup is completed, it will load the RBF file of my project using the "dc" method.
It will start the SMP and then load two cores.
However, when I use ARMDs for debugging, one (or both) of the cores will get suspended. The reason seems to be that some modules involved in FPGA communication fail to find the address after checking it. When I encounter this issue, I recompile the SOF project in Quartus to generate a new RBF file and then try debugging again with ARMDs. Sometimes this works, but most of the time, it still fails.
I’ve also tried only recompiling my ARMDs project, but the debugging results are always the same after each recompilation. Therefore, the only variable is the Quartus Prime recompilation.
Do you have any solutions for this?
Yours
Alex
- BoonBengT_Altera
Moderator
Hi @CAlex,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome.
Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
- BoonBengT_Altera
Moderator
Hi @CAlex,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
- BoonBengT_Altera
Moderator
Hi @CAlex,
Good day, just following up on the previous clarification.
By any chances did you managed to look into it?
Hope to hear from you soon.
Best Wishes
BB
- whitepau_altera
Contributor
Hi CAlex, thanks for the post. I've got a few questions to help me debug this issue.
Do you have a sample project you can upload so that I can check your settings and try and reproduce?Which board and version of Quartus tools are you using?
How can you tell that the cores are suspended, are you just looking at a message in ArmDS?
