snehal_p
Contributor
4 years agoExecuting a application/executable file on customized boot image for DE1SOC board
I'm trying to execute a simple led switch application on customized boot image.
PFA screenshot of the error received.
Can anyone help me diagnose what the issue is?
snehal_...
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
tehjingy_Altera
3 years agoHi Snehal_p
Could you share me the git repo that you got the library for the rtcds3231 ?
Also please share me the make file that you are using to build the library?
Jingyang, Teh
snehal_p
Contributor
3 years ago
