Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Hi
Any update on this case?
Jingyang, Teh
- snehal_p3 years ago
Contributor
Hi Jingyang,
PFA error screenshot while compiling c program. Can you please help me with the library files for rtcds3231 and i2c, also the steps to use .h files
snehal_p
Contributor
Hi Jingyang,
PFA error screenshot while compiling c program. Can you please help me with the library files for rtcds3231 and i2c, also the steps to use .h files. I ge similar error when I try to compile demonstration code for gsensor.
snehal_p
