Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Hi Snehal
Happy New Year!
That is weird.
Could you try to print out the environmental variable " SOCEDS_DEST_ROOT"?
Jingyang, Teh
- snehal_p3 years ago
Contributor
Hello Jingyang,
Thank you!
Happy New Year!
PFA screenshot.
snehal_p
Contributor
Hello Jingyang,
I'm facing issues with the booting process.
zImage and rootfs I'm using are readily available from rocketsboard link.
PFA screenshots one with zImage for 3.10ltsi receiving garbage value after starting kernel and for original terasic console it is getting stuck after starting kernel
snehal_p
