snehal_p
Contributor
4 years agoExecuting a application/executable file on customized boot image for DE1SOC board
I'm trying to execute a simple led switch application on customized boot image.
PFA screenshot of the error received.
Can anyone help me diagnose what the issue is?
snehal_...
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
tehjingy_Altera
3 years agoHi Snehal
Could try following the installation steps for SOCED in the link below:
https://www.rocketboards.org/foswiki/Documentation/SoCEDS#Install_SoC_EDS
You could refer to the linux steps under "Linux Installation".
Jingyang, Teh
