Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Hi Snehal_p
I tried running your application and zImage, there are able to run without crashing.
However I notice that the application is not able to bling the led on the board.
You are working on a DE1SOC or DE0-Nano-Soc?
The link that you shared is using a DE0-Nano-Soc.
Could you share me the source of your application and your quartus image?
To check if you are accessing the correct memory address for the led.
Jingyang, Teh
Hello Jingyang,
I'm using DE1SOC Board. PFA link for demonstration project https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=836&PartNo=4#contents
snehal_p
- snehal_p3 years ago
Contributor
Hello Jingyang,
I'm still facing issues launching DS5 can you PFA screenshot to analyze what the issue is
snehal_p
