Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Hi Snehal_p
I tried running your application and zImage, there are able to run without crashing.
However I notice that the application is not able to bling the led on the board.
You are working on a DE1SOC or DE0-Nano-Soc?
The link that you shared is using a DE0-Nano-Soc.
Could you share me the source of your application and your quartus image?
To check if you are accessing the correct memory address for the led.
Jingyang, Teh
- snehal_p3 years ago
Contributor
Hello Jingyang,
I'm using DE1SOC Board. PFA link for demonstration project https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=836&PartNo=4#contents
snehal_p
Contributor
Hello Jingyang,
I'm still facing issues launching DS5 can you PFA screenshot to analyze what the issue is
snehal_p
