Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Hi
Jingyang, Teh
- snehal_p3 years ago
Contributor
Hello Jingyang,
Thanks for the prompt support, fitter error solved.
Let me test with my zImage, actually problem occurs while executing the application file
Can you try executing hps led hex demostration using my zImage
snehal_p
