Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
HI Snehal_p
Please give me sometime while I try to reproduce the issue on my side here.
I find it weird that it could run once only each time.
Let me try out the steps from the website and try making changes to it whether i could reproduce the issue on your side.
Jingyang, Teh
Hi Jingyang,
Thanks, application file does not run each time we program it executed few times.
snehal_p
