Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Hi snehal_p
Did you tried running the steps under the "Section 11: Writing a User-space Application" in the rocketboard link
https://www.rocketboards.org/foswiki/Documentation/EmbeddedLinuxBeginnerSGuide to recreate the demonstration project led switch application in the new customize linux operating system?
Jingyang, Teh
Hello Jingyang,
Yes, I followed the same steps. It is still giving issues.
Also I'm facing issues in launching DS5 eclipse despite of successful installation. Can you help me with the linux commands to diagnose what the actual issue is.
snehal_p
