Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Hi Snehal
The application that was run on the customized image was it a copied version from the non-customized image?
What are the major changes made to the customized image?
Jingyang, Teh
- snehal_p4 years ago
Contributor
Hello Jingyang,
The application that was run was the demonstration project led switch application. Customization I changed the linux version.
PFA screenshot of the error received when I execute the application file.
snehal_p
