Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Hi snehal_p
Sorry for the late reply as there was a public holiday.
Have you tried running the led application on the non customized image? Is it working?
What are the changes you made to the image?
Did you made any changes to the application code?If yes could you share with me the changes you made?
Did you compile the application on the user space of the non customized image?
Jingyang, Teh
- snehal_p4 years ago
Contributor
Hi Jingyang,
I tried running the application on non customized image ,it works.
Also with customized image it gave output once please find attached screenshot , but again when I try executing it gives error.
snehal_p
