Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Hi snehal_p
Could you share the steps that was used to compile the application file?
What are the environment details run on the DE1SOC board?
Jingyang, Teh
Hello Jingyang,
Thanks for your response, following is the link of steps for compilation
https://www.rocketboards.org/foswiki/Documentation/EmbeddedLinuxBeginnerSGuide
Please let me know if more information is needed
snehal_p
