Executing a application/executable file on customized boot image for DE1SOC board
- 3 years ago
Hi
I have tried out your zImage and able to run the led application successfully.
Please find the screenshot below:
Did you flash the FPGA configuration before booting into the linux environment?
As for the fitter error, you will need to run both of the TCL script below (located:soc_system\synthesis\submodules):
hps_sdram_p0_parameters.tcl
hps_sdram_p0_pin_assignments.tcl
Jingyang, Teh
Hi snehal_p
Could you share the steps that was used to compile the application file?
What are the environment details run on the DE1SOC board?
Jingyang, Teh
- snehal_p4 years ago
Contributor
Hello Jingyang,
Thanks for your response, following is the link of steps for compilation
https://www.rocketboards.org/foswiki/Documentation/EmbeddedLinuxBeginnerSGuide
Please let me know if more information is needed
snehal_p
