driver for HPS I2C Hardware in u-boot 04.2020 deactivates clocks
- 5 years ago
We had a similar problem trying to migrate to the socfpga_v2021.04 branch of uBoot. We have an on-board EEPROM (I2C) that contains factory configuration data that is needed during the uBoot TPL phase.
We are seeing that the designware_i2c I2C controller is resetting the l4_sp_clk when it is removed prior to starting the linux kernel. The result is that there is a bus hang when the kernel tries to access the UART peripheral (which needs that clock). The kernel we are trying to use is from 4.9.78-ltsi. It's possible that later versions of the kernel properly re-enable the l4_sp_clk, but this doesn't seem to be the case for our particular configuration (which works fine with uboot 2014.10). We also had to set the socfpga_legacy_reset_compat=1 uBoot environment variable as well, as without it this version of uBoot will reset all the peripherals as it switches to linux, resulting in a similar hang.
Our work-around can be found in this patch here:
Critical Link LLC git repositories. - u-boot-socfpga.git/blobdiff - drivers/i2c/designware_i2c.c
-Mike
Hi all,
I am facing a similar issue with USB boot. When i try to boot from USB from u-boot, its hanging at starting kernel. In function "dwc2_usb_remove" of drivers/usb/host/dwc2.c, I tried commenting out two functions,
//clk_disable_bulk(&priv->clks);
//clk_release_bulk(&priv->clks);
Now I am able to see the print " Deasserting all peripheral resets ", but still it's not booting. I also tried not to call "dwc2_usb_remove" function but observed the same. Any idea on this issue?
