Does U-boot socfpga_v2019.04 really support LPDDR2?
Kindly make sure to follow the steps here:
https://github.com/altera-opensource/u-boot-socfpga/blob/socfpga_v2019.04/doc/README.socfpga
This will generate the handoff files. Hardware wise it should be supported. Uboot wise, I will check with our internal engineering to confirm if 2019.04 supports LPDDR2
Thank you
- tlang156 years ago
I've been using the work flow described in README.socfpga and also on https://rocketboards.org/foswiki/Documentation/BuildingBootloader
- GBies6 years ago
So have You figured out whether the lpddr2 is suported?
I'm trying to build spl for project generated in q20.1 with CycV and LPDDR2 but have very simmilar compile time errors.
Should I use q18.1 for this?
- Tony_7775 years ago
@FawazJ_Altera, has Intel stopped supporting LPDDR2?
Which Quartus and SoCEDS version should I use to build the bootloaders for the board with LPDDR2?
