K606
Contributor
1 year ago"DMA engine initialization failed" error when EMAC uses GMII interface
I am seeing the error given here when I boot the Agilex A5 (Quartus 24.3). This doc recommends to connect mac_tx_clk_i to a 2.5/25 MHz clock source 'correctly'. What does it mean, 'correctly'? ...
NiravR_Altera
1 year agoHello K,
Thank you for reaching out. Since you've already provided detailed information about your design and the issue you're facing in this thread (Agilex 5 EMAC to EMAC : Driver error), we recommend continuing the discussion there instead of starting a new one. This helps ensure that everyone assisting you has full context and background on the problem you're facing.
- K6061 year ago
Contributor
Ok! Thanks for telling me. Do fell free to delete the post.
K
