fletcher-wadsworth
1 year agoDirect ATF to Linux from QSPI boot flow not working
I have a board with an Agilex SoC device. Trying to debug the Altera TSE IP operation with the appropriate Linux drivers. However, the SD card reader is having hardware problems, so I would like to i...
RolandoS_Altera
1 year agoHello
Thanks to contact Altera. My name is Rolando and will assist you with this issue. The build instructions provided were tested for 25.1 release and they were working properly by the time they were created using the 25.1 release repositories. I will rebuild the binaries again adding some log messages to the functions that you describe above to get the values that are being assigned in the data structure and also see what flow is being follow once the data in the structure is retrieved (see how it handles the dtb marked as Non-Executable). I will share the results once I got them.
Rolando
