STATEABC's avatar
STATEABC
2 years ago
Demosaic IP output is incorrect
Hello, I used demosaic IP in my project, but unfortunately it didn't work
My quartus version is 24.2, I used demosaic IP in Platform, here are some of my settings:
Input bits per color sample: 10
Output bit per color sample: 8
Number of pixels in parallel: 4
Maximum field height: 1024
Maximum field width: 2048
No options in General are used
The main_clock of demosaic is 100MHz, axi4s_vid_in is connected to the video_streaming_interface_0 interface of MIPI CSI2 IP, and the data output by the video_streaming_interface_0 interface is normal, av_mm_control_agent is connected to nios v
But according to the waveform captured by signal tap, demosaic The IP output axi4s_vid_in_tready is always low, and the output axi4s_vid_out_tdata is always a fixed value, such as 000000000000000000909090h
I want to know how to use this IP correctly, any help is appreciated, thank you.
  • STATEABC's avatar
    STATEABC
    Can someone help me?
    I read the values of some registers and found that they were very different from the Settings:
    VID_PID:6af70246
    VERSION:10
    LITE_MODE:4
    DEBUG_ENABLED:305441741
    BPS_IN:305441741
    BPS_OUT:305441741
    NUM_COLOR_IN:305441741
    NUM_COLOR_OUT:305441741
    PIP:305441741
    MAX_WIDTH:305441741
    MAX_HEIGHT:305441741
    IMG_INFO_WIDTH:640
    IMG_INFO_HEIGHT:480
    STATUS:1
    STATUS:110
  • Farabi_Altera's avatar
    Farabi_Altera
    "We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
    Thank you for your understanding."
    Farabi_Altera
  • Wincent_Altera's avatar
    Wincent_Altera
    I am Wincent to assist you on the Domestic IP, may I know which FPGA device that you currently trying with ?
    Regarding the parameter setting of domestic IP, you may refer to https://www.intel.com/content/www/us/en/docs/programmable/683329/24-2/demosaic-ip-parameters.html
    Other detail about the IP you may refer to https://www.intel.com/content/www/us/en/docs/programmable/683329/24-2/demosaic.html
    Let me know if you have any further question, or you feel anything else I could help you.
    Wincent_Altera
    Wincent_Altera
    I wish to follow up with you about this case.
    Do you have any further questions on this matter ?
    ​​​​​​​Else I would like to have your permission to close this forum ticket. Nevertheless, you can still response to the forum and I will be available to assist you.
    Wincent_Altera
    p/s: If any answer from the community or Altera Support is helpful, please feel free to give the best answer or rate 9/10 survey.
    Wincent_Altera
    Hi
    We have not hear from you and this Case is idling. It is not recommended to idle for a week.
    Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
    Hence, This thread will be transitioned to community support.
    If you have a new question, feel free to open a new thread to get support from Altera experts.
    Otherwise, the community users will continue to help you on this thread. Thank you
    If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me via this forum page of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
    Wincent_Altera
