CycloneV MPU clock frequency
I am using the CycloneV 5CSXFC6C6U23I7 SoC. According to the specifications cyclone V, SX models should allow for a core frequency of up to 925 MHz.
However, when I try to change the Hard Processor Settings in the Platform designer I get the following error message:
"Error: hps_0: "MPU clock frequency" (desired_mpu_clk_mhz) 900.0 is out of range: 25.0-800.0"
Could someone tell me how I can avoid this, or in other words:
Could someone tell me how to set the MPU frequency of the 5CSXFC6C6U23I7 SoC to 900 MHz.
Many thanks in advance.
Andreas
- EBERLAZARE_I_Intel
Have you changed the device assignment correctly in Quartus settings?
I didn't get the Quartus version that you are using, can you share the version that you are testing on?
- aurec2
Hi.
thanks for your answer. The device settings are correct, both in the platform designer and in quartus project. Normally I am using Quartus Prime 17.1.
The mentioned problem occurs in using Quartus Prime 17.1 and in Quartus Prime 19.1.
Best
Andre
I recommend that you check the "MPU clock frequency" at the default value of 800 MHz. At boot-up, please re-check the clock frequency again.
