CycloneV MPU clock frequency
Hi.
thanks for your answer. The device settings are correct, both in the platform designer and in quartus project. Normally I am using Quartus Prime 17.1.
The mentioned problem occurs in using Quartus Prime 17.1 and in Quartus Prime 19.1.
Best
Andre
I recommend that you check the "MPU clock frequency" at the default value of 800 MHz. At boot-up, please re-check the clock frequency again.
- aurec25 years ago
thanks for your answer. This is what I did, i.e. currently the device runs at 800 MHz. On booting up the SPL confirms that the MPU frequency is set at 800 MHz.
As you are certainly aware - the specified device allows for a MPU frequency of 925 MHz.
Are there any specific steps, other than choosing the correct device in the Platform designer?
As for now I still can only choose 800 MHz as a MPU frequency in the Platform designer.
Answers would be appreciated.
Many thanks ,Andreas.
- EBERLAZARE_I_Intel5 years ago
After rechecking, unfortunately you may have read the part number wrongly, you may refer below on what your part number represents, yours is a C7 speed grade, not a C6, which has max 800MHz supported clock speed:
A C6 should have part number as 5CSXFC6D6F31C*6*N
Performance reference:
- aurec25 years ago
thanks for your answer. Indeed I was not aware of the fact that only device with the fastest speed grade can be clocked with 925 MHz.
Tanks for your support.
Andreas
