Cyclone V HPS bus - FPGA-to-SDRAM
Hi @BrianSune_Froum ,
Thanks for you posting.
First, Let me confirm how FPGA-to-SDRAM bridge can be configured.
"There is a maximum of six command ports, four 64-bit read data port and four 64-bit
write data port."
These three types of ports can be combined to form multiple Avalon-MM/AXI interfaces.
The table 5 to which you refer shows which ports and how many are required for each interface.
For example : You can configure
1x 64bit AXI (2:CommandPorts, 1:ReadPort, 1:WritePort)
1x 128bit Avalon-MM Write Only (1:CommandPort, 0:ReadPort, 2:WritePorts)
1x 128bit Avalon-MM Read Only (1:CommandPort, 2:ReadPorts, 0:WritePort)
1x 64bit Avalon-MM Bidirectional (1xCommandPort, 1xReadPort, 1xWritePort)
The above configuration utilizes 4:CommandPorts, 4:ReadPorts, 4:WritePorts. (2:CommandPorts are un-used.)
Is there something strange or wrongly labeled?
