Custom board on Cyclone V HPS SDRAM preloader test
- 1 year ago
The final result is that even with a fly-by routed topology there are no issue on both 1.5V and 1.35V DDR3 DDR3L.
The MT41K128M16 /w 1k page size shows no sanity issue on memtest stresapptest on distro.
UBOOT memory normal test also passed w/o any errors.
So after short testing we can only assume there are inherent bug on Quartus 18.1? or HPS IP.
No matter it is /w or /wo the board settings no drop no crash no stuck.
So the case ends here.
Hi Brian,
May I know what are the device tree settings for U-boot? Could you provide us the devicetree file that you're using?
Kian
- BrianSune_Froum1 year ago
Contributor
I think you are referring to the kernel dts?
For U-Boot I never touch it because I am using Quartus 18.1For that flow bsp-editor will create the MakeFile.
Once it runs make -all and make uboot
It will unzip the uboot zip from local install folder rather like newest FPGA device form GIT.
For kernel dts```
// SPDX-License-Identifier: GPL-2.0/** Copyright Altera Corporation (C) 2015. All rights reserved.*/#include "socfpga_cyclone5_b.dtsi"//#include <dt-bindings/gpio/gpio.h>/ {model = "Custom Board Cyclone V Soc";compatible = "altr,socfpga-cyclone5", "altr,socfpga";aliases {ethernet0 = &gmac1;};chosen {bootargs = "earlyprintk";stdout-path = "serial0:115200n8";};memory@0 {name = "memory";device_type = "memory";reg = <0x0 0x20000000>; /* 512MB */};```
