Custom board on Cyclone V HPS SDRAM preloader test
- 1 year ago
The final result is that even with a fly-by routed topology there are no issue on both 1.5V and 1.35V DDR3 DDR3L.
The MT41K128M16 /w 1k page size shows no sanity issue on memtest stresapptest on distro.
UBOOT memory normal test also passed w/o any errors.
So after short testing we can only assume there are inherent bug on Quartus 18.1? or HPS IP.
No matter it is /w or /wo the board settings no drop no crash no stuck.
So the case ends here.
Hi
What SDRAM Size that you are using?
Did you define the correct SDRAM size in the device tree as the sdram installed on the board?
Jingyang, Teh
- BrianSune_Froum1 year ago
Contributor
I think this is caused by the fly-by routing.
There are two mt41k256m16.
But even I disassembled the far end die it is still not working properly.
Do there any way I can reduce the clock to 250M or 200M for sanity test?
I am so puzzling that with a 8 layer board on fly-by 50ohm and 100ohm design sill can't make things work?
Contributor
New data
If I do in purposed and messed up the DLL of the DDR and force it to run 25MHz 256x16 is able to pass the test and even run the distro normally.
If I just remain the lower byte of the remain MT41K25616 DDR die it can pass the startup test as well and run 300MHz on C8 speed grade.
How could this even possible when lower byte can work but not both lower and upper byte?
Please do help
