Cache coherency on Agilex 5 when booting secondary cores without ATF
- 1 year ago
I would suggest that you boot through the default bootloaders into your application so you can leverage all of the default configurations that they apply to the HPS for you, rather than trying to accurately replicate that in your own custom boot sequence. The FSBL which can be the ATF bl2 code but is typically the u-boot-spl code, will configure the HPS in general, ensuring that the HPS handoff data is correctly applied to the HPS, which gets the clocking and HPS IO and HPS EMIF all configured as the HPS was configured to operate in the Quartus project, and then it configures all the secure registers in the firewalls and things like that to get the HPS in the operational state that you expect. Then it passes control to the ATF bl31 code which finishes configuring the DSU and CPU cluster for proper default behavior. You would need to replicate all of that functionality in your own custom boot sequence to bring things up to a similar state.
If you need to use group 0 GIC interrupts, then you'll need to configure those from a secure state. Your realistic options are secure EL3 or secure EL1. To do this in S-EL3 state with the ATF code present, you'd be better served to apply your own customizations into the ATF code base and interact with your NS-EL2 application. To do this in S-EL1 state with the ATF code present, you'd need to start your secondary core and it's application to enter S-EL1 state and then operate from there.
Apologies for the delayed response.
It took some time to work through the technical details, but I’ve now used the Trusted Secure Payload (TSP) as an entry point into Secure EL1. From there, I was able to configure the Group 0 interrupts as needed for our use case.
Thanks again for the guidance. It was very helpful.
Small correction, I meant the Test Secure Payload.
