PHJ
7 years agoBug in hwlibs alt_qspi.c driver ?
I've run into a problem trying to use the hwlibs alt_qspi.c flash driver on the Arria 10 SoC DevKit. This is the version that came with the SoCFPGA-GettingStarted-A10-GCC example: * $Id: //acds/re...
- 7 years ago
I have pushed this issue thru our supplier to Intel to get an answer.
This is their response:
I have reproduced the issue and I believe I have found the root cause. Please poll for QSPI controller register cfg field idle until it is equal to 1 at the end of the function alt_qspi_stig_cmd_helper() and it will fix the issue.I have patched alt_qspi.c with this change and it does fix the issue we were seeing.
FawazJ_Altera
7 years agoThank you for your information.
I will send these details to our internal team for their investigation.
