8 years agobsp-create-settings --type spl error
i have installed SoC EDS 17.0 on Ubuntu 14.04.5 LTS x64, but path for bsp-create-settings was not set in envirment variable
$ bsp-create-settings
bsp-create-settings: command not found so i export as follows $export PATH=$PATH:/home/soft/intelFPGA_pro/17.0/embedded/host_tools/altera/preloadergen/ then tried again $bsp-create-settings
--type spl
--bsp-dir software/preloader
--preloader-settings-dir "hps_isw_handoff/soc_system_hps_0"
--settings software/preloader/settings.bsp
--set spl.boot.WATCHDOG_ENABLE false --set spl.boot.SDRAM_SCRUBBING true
INFO: Creating BSP settings file...
INFO: nios2-bsp-create-settings --type spl --bsp-dir software/preloader --preloader-settings-dir hps_isw_handoff/soc_system_hps_0 --settings software/preloader/settings.bsp --set spl.boot.WATCHDOG_ENABLE false --set spl.boot.SDRAM_SCRUBBING true
SEVERE: Available BSP type values for the --type argument are:
SEVERE: nios2-bsp-create-settings failed.
make: *** Error 1 i dont undertand the error exactly, i think its related to --type spl option. can anyone please tell me how to overcome this error?5 Replies
Yes it looks like bsp-create-settings is missing the spl type. what do you get when you execute
(with the question mark)? For me it saysbsp-create-settings --type \?
It could be that your environment is not set up correctly. I don't think that setting the PATH is enough, Altera provides a script that sets up the environment for you. I don't remember where it comes from, but on my installation I've copied it to /usr/local/bin. Here are the contents:Available BSP types are:
(just replace _SOCEDS_ROOT with wherever your Quartus version is installed). Has you see it defines a root path for the SOC EDS and executes a script there. This script sets up a bunch of environment variables that are required by some tools. I have never created a preloader configuration from the command line myself though, I've always used the bsp editor (type bsp-editor from your command line)#!/bin/bash # ########################################################### # # # Altera SoC Embedded Command Shell # # # # # # Copyright (c) 2016 Altera Corporation # # All Rights Reserved. # # # # ########################################################### _SOCEDS_ROOT="/usr/local/intelFPGA/16.1/embedded" export SOCEDS_DEST_ROOT="${_SOCEDS_ROOT}" source "${_SOCEDS_ROOT}/env.sh" # ########################################################### unset _SOCEDS_ROOT - Altera_Forum
--- Quote Start --- Yes it looks like bsp-create-settings is missing the spl type. what do you get when you execute
--- Quote End --- for me it showsAvailable BSP types are:
--- Quote Start --- It could be that your environment is not set up correctly. I don't think that setting the PATH is enough, Altera provides a script that sets up the environment for you. I don't remember where it comes from, but on my installation I've copied it to /usr/local/bin. Here are the contents: --- Quote End --- i have allready in Soc Command Shell by $embedded/embedded_command_shell.sh$ bsp-create-settings --type \? Available BSP types are:
--- Quote Start --- I have never created a preloader configuration from the command line myself though, I've always used the bsp editor (type bsp-editor from your command line) --- Quote End --- as per your suggestion i tried for bsp-editor, but as i create new HPS bsp, there is no drop down option for 'Cyclone V' and also the ok button is disable on selection of preloader setting directory.#!/bin/bash # ########################################################### # # # Altera SoC Embedded Command Shell # # # # # # Copyright (c) 2017 Altera Corporation # # All Rights Reserved. # # # # ########################################################### # ########################################################### # # Get the Root SOCEDS directory # if ; then _IS_WINDOWS=1 if ; then export ORIGINAL_PATH="${PATH}" PATH="/bin:/usr/bin" fi fi if && ; then _IS_CYGWIN=1 fi _SOCEDS_ROOT=$(cd "$(dirname "${0}")" && echo "$(pwd 2>/dev/null)") if ; then echo "${_SOCEDS_ROOT} not found. Invalid or corrupt SOCEDS Install" 1>&2 exit 1 fi export SOCEDS_DEST_ROOT="${_SOCEDS_ROOT}" if ; then SOCEDS_DEST_ROOT="$(cygpath -m "${SOCEDS_DEST_ROOT}" 2>/dev/null)" fi source "${_SOCEDS_ROOT}/env.sh" # ########################################################### unset _SOCEDS_ROOT unset _IS_WINDOWS unset _IS_CYGWIN if ; then exec "$@" else echo "------------------------------------------------" echo "Altera Embedded Command Shell" echo echo "Version 17.0 " echo "------------------------------------------------" # Use bash --norc to get a clean shell # Use bash --rcfile <bashrc> to for a user rcfile # Default to using ~/.bashrc exec bash fi - Altera_Forum
So if it is not your environment, could it be that a part of the installation is missing? When you installed Quartus, did you also install the Cyclone V device and the Soc EDS? All the devices are in a separate installation, and so does the Soc EDC if I remember correctly.
Thanks for reply,
--- Quote Start --- So if it is not your environment, could it be that a part of the installation is missing? --- Quote End --- For safe side, I have reinstall the Soc EDS. But the result is same. --- Quote Start --- When you installed Quartus, did you also install the Cyclone V device and the Soc EDS? All the devices are in a separate installation, and so does the Soc EDC if I remember correctly. --- Quote End --- yes i have installed Cyclone V device and the Soc EDS with Quartus, I can build Quartus project for cyclone V in current installation. - Altera_Forum
same here. when starting bsp-editor from eds environment, it displays:
INFO: Initializing BSP components... 2018.03.19.10:20:48 Conan.addPluginPath:477 (3) adding search path "/home/**/intelFPGA_lite/17.1/quartus/sopc_builder/bin/root_components.ipx" as "/home/**/intelFPGA_lite/17.1/quar - tus/sopc_builder/bin/root_components.ipx" because ipx file looks like the path is broken
