8 years agobsp-create-settings --type spl error
i have installed SoC EDS 17.0 on Ubuntu 14.04.5 LTS x64, but path for bsp-create-settings was not set in envirment variable $ bsp-create-settings
bsp-create-settings: command not found so...
8 years agoThanks for reply,
--- Quote Start --- So if it is not your environment, could it be that a part of the installation is missing? --- Quote End --- For safe side, I have reinstall the Soc EDS. But the result is same. --- Quote Start --- When you installed Quartus, did you also install the Cyclone V device and the Soc EDS? All the devices are in a separate installation, and so does the Soc EDC if I remember correctly. --- Quote End --- yes i have installed Cyclone V device and the Soc EDS with Quartus, I can build Quartus project for cyclone V in current installation.
