8 years agobsp-create-settings --type spl error
i have installed SoC EDS 17.0 on Ubuntu 14.04.5 LTS x64, but path for bsp-create-settings was not set in envirment variable $ bsp-create-settings
bsp-create-settings: command not found so...
8 years agoYes it looks like bsp-create-settings is missing the spl type. what do you get when you execute
bsp-create-settings --type \? (with the question mark)? For me it saysAvailable BSP types are: It could be that your environment is not set up correctly. I don't think that setting the PATH is enough, Altera provides a script that sets up the environment for you. I don't remember where it comes from, but on my installation I've copied it to /usr/local/bin. Here are the contents: #!/bin/bash
# Altera SoC Embedded Command Shell #
# Copyright (c) 2016 Altera Corporation #
# All Rights Reserved. #
_SOCEDS_ROOT="/usr/local/intelFPGA/16.1/embedded"
export SOCEDS_DEST_ROOT="${_SOCEDS_ROOT}"
source "${_SOCEDS_ROOT}/env.sh"
unset _SOCEDS_ROOT
(just replace _SOCEDS_ROOT with wherever your Quartus version is installed). Has you see it defines a root path for the SOC EDS and executes a script there. This script sets up a bunch of environment variables that are required by some tools. I have never created a preloader configuration from the command line myself though, I've always used the bsp editor (type bsp-editor from your command line)
