CAlex's avatar
CAlex
8 months ago
Baremetal Example SDMMC makefile failed
CycloneVsoc with BM environment, SOCEDS 20.1 and ARMDS 2021
I downloaded your bare-metal SDMMC sample, but the build failed when using ARMDS make. Here is the error message:
make all
arm-altera-eabi-gcc -g -O0 -Wall -Werror -std=c99 -mcpu=cortex-a9 -mfloat-abi=softfp -mfpu=neon -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -Dsoc_cv_av -c sdmmc_demo.c -o sdmmc_demo.o
process_begin: CreateProcess(NULL, arm-altera-eabi-gcc -g -O0 -Wall -Werror -std=c99 -mcpu=cortex-a9 -mfloat-abi=softfp -mfpu=neon -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include -IC:/intelFPGA/20.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -Dsoc_cv_av -c sdmmc_demo.c -o sdmmc_demo.o, ...) failed.
make (e=2)
Before making I've point the SOCEDS_DEST_ROOT to my SOC path.
And I've opened the embedded_command_shell.
Thank you
Alex
  • KianHinT_altera's avatar
    KianHinT_altera
    Hi Alex
    Kian
    KianHinT_altera
    Hi Alex,
    May I know what's the status on this issue, whether the issue has been resolved on your end?
    Kian
    KianHinT_altera
    Hi Alex,
    Could you help provide the information that Alif requested, particularly on whether you have the arm-altera-eabi-gcc compiler in your machine?
    Kian
  • Hi Alex,
    This also could be because of arm-altera-eabi-gcc compiler is not found in your environment.
    Can you help to confirm whether arm-altera-eabi-gcc exists in your PATH?
    You could try checking "C:\intelFPGA\20.1\embedded\host_tools\gnu\arm\2019.12\bin" or the likes of it.
    Alif
