Arria10 SoC U-boot: How to configure DDRAM memory from 1GB to 4GB in version 23.2 PRO
Nora
Hi
Any update on this case?
Jingyang, Teh
- tehjingy_Altera
Hi Nora
The changes in the device tree looks good at the moment.
Did you increase the DDR size in the Hardware Design too?
Jingyang, Teh
- ALT3224
Hi Jingyang,
yes, I increased the DDR size in the Hardware Design
If my memory node definition is ok , I assume that I'm missing some change
How to configuring DDR in u-boot ?
Nora
- tehjingy_Altera
Hi Nora
Is it ok if you could share with us your quartus project?
Could you also share with us the error message that you are seeing?
Jingyang, Teh
- ALT3224
Hi Jingyang,
Currently, I'm checking a new quartus project, probably it wil resolve the problem
Which tool can I use to create the device tree in version 23.2 ?
Nora
- tehjingy_Altera
Hi
Jingyang, Teh
- tehjingy_Altera
Hi Nora
There are no specific tool to generate the device tree for the Arria10 Soc.
One method to make the changes is to edit the GSRD available for the Arria10 Soc.
You could get the GSRD from the link below:
https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD
The device tree for uboot are in the location:
https://github.com/altera-opensource/u-boot-socfpga/tree/socfpga_v2023.07/arch/arm/dts
The linux device tree is located in the location below:
https://github.com/altera-opensource/linux-socfpga/tree/socfpga-6.1.55-lts/arch/arm/boot/dts
Jingyang, Teh
- ALT3224
Hi Jingyang,
Thanks for your fast answer
Nora
- tehjingy_Altera
Hi Nora
Any follow up question regarding this case?
Jingyang, Teh
- tehjingy_Altera
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
