Arria10 Secure Boot : unable to boot SPL FUSE
Hi @nareshrkumar,
Thanks you for your feedback.
I'm working with Christian and Baptiste. Without further information, the project, that we working on is currently at a deadlock situation.
Do you have new information about how to bypass the reset that can be triggered by quartus ?
- Have you encountered/known issues with certain Quartus version ? (standard, pro or specific version number)
- If the USB blaster forces the reset, is there a method to bypass it using Quartus?
Théo
Hi Theo, Christian and Baptiste
Thank you for the information shared.
As of today, I am not aware of any known issues with a Quartus version.
As the issue involves multiple components, U-Boot, Quartus, programmer and signing tool etc., I am working with different teams internally to get definitive information. Please give me some more time, I will update you on the status.
Naresh
- ThFo1 year ago
Hi nareshrkumar,
Thank you for your help, we are still listening.
Christian & Baptiste & Théo
- nareshrkumar1 year ago
Thank you for the wait.
I have collected the information relevant to various use cases for Secure Boot in A10 but I need the below information to narrow it to your use case and help with the same.
My questions:
1. What is your objective with the Secure Boot in A10, is it for image authentication, encryption or both?
2. Also, can you please share all the steps you have run for the "fuse" use case?
Naresh
- ThFo1 year ago
Hi @nareshrkumar , @Jeet14
About your previous questions :
Our objective is to enable image authentification only.2. Also, can you please share all the steps you have run for the "fuse" use case?
The steps followed for the "fuse" use case are identical to those for "user" mode (first post), except that when executing "alt_authtool.py", we use the "sign -t fuse" option instead of "sign -t user".If you have any further questions, please don't hesitate to ask.
