bsp_user
3 years agoarria V compiler and hwlibs
My goal is to successfully build and run a bare-metal app which measure time by reading one of the the Arria V Soc HPS timers using hwlib. Afterwards I wish to use the same app on a custom boar...
- 3 years ago
Since the case have been open for too long, we recommend that we close the thread as per our support procedure.
However, I highly recommend that you open issues that you'd face separately, for e.g your help needed for Quartus compilation on another then the Baremetal build on next.
Once you open the new case/s, we will support your issue then. Hopes this helps.
bsp_user
3 years agoI'll do it, based on your previous replies.
Thank you very much
