arria V compiler and hwlibs
- 3 years ago
Since the case have been open for too long, we recommend that we close the thread as per our support procedure.
However, I highly recommend that you open issues that you'd face separately, for e.g your help needed for Quartus compilation on another then the Baremetal build on next.
Once you open the new case/s, we will support your issue then. Hopes this helps.
If you're new, please check the following video for reference on the flow of Quartus build in part 1 and part 2:
https://www.youtube.com/watch?v=8BehnPg8IvM&ab_channel=IntelFPGA
https://www.youtube.com/watch?v=L8FMSy7Uxjc&ab_channel=IntelFPGA
The video is just for your reference, it is using old flow but they are almost similar.
For your step, in Quartus GUI, locate and open the GHRD's Project file ".qpf" in then compile to get the handoff folder to proceed.
