arria V compiler and hwlibs
- 3 years ago
Since the case have been open for too long, we recommend that we close the thread as per our support procedure.
However, I highly recommend that you open issues that you'd face separately, for e.g your help needed for Quartus compilation on another then the Baremetal build on next.
Once you open the new case/s, we will support your issue then. Hopes this helps.
Anyway, please pin the steps I've given, it will be useful for reference point of view.
One question, for QSPI would you want something like a U-boot SPL to show some logs. The build is to get the U-boot SPL binary, and stop after finishing the U-boot steps not Linux.
If you just want it to work on the ARM debugger you need the application.axf to be loaded from ARM DS.
I have not tried personally on Windows, it is best if you have a virtual machine and get Ubuntu 20.04 >, if you proceed on Windows you need to make sure you have install linaro:
https://www.rocketboards.org/foswiki/Documentation/SoCEDS#Install_Linaro_Bare_45metal_AN1
It should be similar as in DS-5, the flow should see something like this:
You still need to build the U-boot. Please check the above flow, and let me know which steps are you having issues with based on the above steps.
