arria V compiler and hwlibs
- 3 years ago
Since the case have been open for too long, we recommend that we close the thread as per our support procedure.
However, I highly recommend that you open issues that you'd face separately, for e.g your help needed for Quartus compilation on another then the Baremetal build on next.
Once you open the new case/s, we will support your issue then. Hopes this helps.
For preloader + hello world, I have the steps that I did on our Cyclone V SoC dev kit flashed to the QSPI.
I will try to find and provide to you.
- bsp_user3 years ago
I appreciate it.
I don't know how to debug the problem.
1. Can I change the preloader startup prints? (this way I'll know I'm using the latest version after modifying it)
2. Does this problem can relate to scatter file?
3. Can I debug the exact process of the preloader, see which address it tries to load and figure if my app is indeed flashed there?
