Sajeev_antony
2 months agoAltera TOD clock IP with HPS for PTP time sync
We have interfaced the TOD clock IP with Stratix 10 HPS LWH2F bridge with below settings, The LWH2F runs at 100Mhz and the TOD clock is 500Mhz. We need to know, how to load the intial time at...
EstebanVV_Altera
2 months agoHi,
I recommend starting from:
If the clock frequency of the bridge is 100Mhz, then it is recommended to connect the clock of the register (Avalon Memory Map) Interface to that same 100MHz, this is to read/write register values.
- For example, following the guide if you write to registers 0x00, 0x01, and 0x02 you will be able to load the seconds and nanoseconds values.
- Same set of registers will help you to do this.
- That conduit is the PPS output
- Already answered.
- Sajeev_antony2 months ago
csr_clock is connected to 100Mhz, and period_clock is connected to 500Mhz.
both resets are made high assuming they are active low reset inputs.
- EstebanVV_Altera2 months ago
You can see here
That reset are active low "rst_n"
