[Agilex]: Programming & Flashing FPGA File (.jic) to QSPI Flash from HPS through ethernet
Hi Raju
Sorry that I did not catch your intention the first time.
We do not support flashing the other than using the JTAG or USB Blaster.
Do you mind giving more details on your use case of flashing through ethernet? Are you referring to a device upgrade on the field device?
For your question regarding file conversion, you could use the "Programming File Generator" tool under the "File>>Programming File Generator".
Jingyang, Teh
Hi @JingyangTeh_Altera ,
We are using as EMMC Flash as the booting device for Agilex Board.
The below files are required
->(.img) file containing u-boot & linux (EMMC Flash)
->(.jic) file containing fpga configuration & u-boot-spl (QSPI Flash)
We need to flash the fpga configuration file through HPS Ethernet (Field Upgrade) ?
Agilex 7 SoC With eMMC Storage On HPS | Projects | RocketBoards.org
Please suggest us any steps.
Thanks & Regards
Raju S
